Hi Is there is any way to turn the EN of the DF Solar controller 5V by default to LOW?
2024-11-26 23:30:27
EN can be seen as an input pin. EN controls a MOSFET, and the 5V output of the Solar power manager will only be enabled when the EN input is high. If your ALARM camera can output 5V and 0V, you can connect the GND of the ALARM camera to the GND of the blue pin of the Solar Power Manager, and then connect the ALARM signal output line to EN.
