Forum >SEN0001 URM37 V5.0 Often Return 0cm Distance Measure
Troubleshooting
userHead Stefanus Ade.Setiawan 2024-11-28 15:21:17 193 Views2 Replies
Hello, i'm trying to use URM37 V5.0 sensor interfacing with ESP32C3 Super Mini With the tutorial example PWM trigger mode
2024-11-28 16:28:38
I follow the example from https://wiki.dfrobot.com/URM37_V5.0_Ultrasonic_Sensor_SKU_SEN0001_#target_4
userHeadPic Stefanus Ade.Setiawan
2024-11-28 16:28:06
Here is my serial monitor output:
Distance=0cm
Distance=106cm
Distance=106cm
Distance=0cm
Distance=106cm
Distance=0cm
Distance=106cm
Distance=0cm
Distance=0cm
Distance=0cm
Distance=0cm
Distance=0cm
Distance=106cm
Distance=0cm
