Forum >Does BH1750 actually work at 3.3V?
General Arduino
userHead Tigger 2024-12-01 09:06:07 497 Views2 Replies
Configured using default pins using Raspberry Pi Pico W and sample code from:
https://wiki.dfrobot.com/Light_Sensor__SKU_SEN0097_
Doesn't work. I2C seems to connect but RequestFrom always results in zero bytes returned.
Tried both controller 0 and controller 1.
Has anyone else had success with this module?  What is the other potential I2C address? (other than 0x23)
2024-12-01 09:29:46
I got it working on an old Arduino UNO.
Next steps: is it too slow for the RP2040 or does it not work at 3.3V as claimed by DFRobot?
userHeadPic Tigger
Yeez_B wrote:
You can try to use UNO's 3.3V to power it and test it again. If the sensor can work properly with UNO's 3.3V, then it is not a power supply problem. DFRobot's wiki also shows that the sensor can work at 3~5V.
Next you need to check whether the sensor is connected to GP20 and GP21, because PR2040 has two I2C buses, and the wire corresponds to I2C0.
2024-12-02 23:39:31
