Forum >DFR0548 micro:Driver - Driver Expansion Board for micro:bit / UNIHIKER
userHead Mesterel 2024-12-01 21:14:50 3225 Views1 Replies
hello, i am trying to use the microbit compass sensor while plugged in the expansion board, but the microbit shows only constant data (around 80 to 110 degrees), if i disconnect the microbit from the expansion board it works fine, what could be the problem? does the board uses a pin that the compass is connected and overwrites it? even if the board is off with the switch it still shows constant data.
2024-12-01 21:27:21
also, i am using microbit v2.21 and i saw that microbit v2 has a separate internal i2c for compass and accelerometer, so what is the issue, is the expansion board overwriting the internal instead of the extarnal i2c bus?
userHeadPic Mesterel
