Forum >FIT0976 - USB Power Supply for Raspberry Pi 5 (5V/5A, US Standard, UL and FCC Certified)
userHead Aftet.Tetfa 2024-12-02 18:00:15 1136 Views1 Replies
Is this a PD type? Can I use this with non-PD devices? I need a 5V/5A non-PD adapter.
Thank you.
2024-12-02 19:30:52
The FIT0976 USB Power Supply for Raspberry Pi 5 is likely a USB Power Delivery (PD) type, as it is designed specifically for the Raspberry Pi 5. If you're looking for a non-PD adapter that provides 5V/5A, this supply may not be the best choice.
userHeadPic lia.ifat
