Forum >SEN0494: Can Two Cameras be Synchronize Together?
userHead An.Ly 2024-12-07 09:31:57 972 Views2 Replies
Anybody knows whether two SEN0494 cameras can be synchronize together? The camera is using the IMX477 image sensor and I know that has synchronization capability, specifically by using the XVS signal. Does the SEN0494 board bring this signal to a connector or somewhere else on the board where I can solder a wire to it? Thanks.
2024-12-08 01:27:22
Examine the SEN0494 board to see if there are labelled test points, pads, or connectors that reference XVS, TRIG, EXT_SYNC, or a similar signal.
userHeadPic lia.ifat
An.Ly wrote:
I haven't purchased the boards yet, waiting until I can verify I can synchronize two of them for stereoscopic. Anybody has pictures of the top/bottom of board that may give me a clue? Thank you.
2024-12-10 01:29:36
