Forum >Using the SIM7600G-H 4G(LTE) Arduino Shield
General Arduino
userHead ALEX.DRYSDALE 2024-12-09 04:43:46 1752 Views1 Replies
As a new user, it would be helpful to have some easy-to-find simple first-step guides to start using this shield with the Arduino UNO.
The Wiki has all the detailed technical answers which is great. But it seems to ignore that the shield is attached to an UNO and the normal way to talk to an UNO is via the Arduino Sketch interface. Or have I missed something obvious?
2024-12-25 00:41:15
Hi, This is all I could find, hope it helps
#include <SoftwareSerial.h>
SoftwareSerial SIM7670Serial(17,16); // RX, TX of your arduino/ESP8266/ESP32
 Serial.begin(115200);
 SIM7670Serial.begin(115200);
 sendATCommand("AT", "OK", 1000); // check communication
 sendATCommand("AT+CMGF=1", "OK", 1000); // set SMS format to text
 sendSMS("07919316468", "Hello from Arduino!");
 delay(30000);
void sendSMS(String number, String message) {
 String cmd = "AT+CMGS=\"" + number + "\"\r\n";
 SIM7670Serial.print(cmd);
 delay(100);
 SIM7670Serial.println(message);
 delay(100);
 SIM7670Serial.write(0x1A); // send ctrl-z
 delay(100);
void sendATCommand(String cmd, String expectedResponse, int timeout) {
 SIM7670Serial.println(cmd);
 String response = "";
 long timeStart = millis();
 while (millis() - timeStart < timeout) {
   while (SIM7670Serial.available() > 0) {
     char c = SIM7670Serial.read();
     response += c;
   if (response.indexOf(expectedResponse) != -1) {
     break;
 Serial.println(response);
userHeadPic Harry.Powney
