Forum >ME007YS use as trigger
Dear all,
I'm using ME007YS model, and I'd like to use the sensor with trigger.
Now I'm use the sensor is connected with PC through “Waveshere USB to 4ch TTL”.
How can I use the sensor with trigger?
And I saw there are two version about ME007Y (Serial and PWM).
(I think i have serial version)
Anyway, serial version can use trigger system?
Thanks.
2024-12-09 21:55:43
lia.ifat
Check the command syntax, baud rate and communication settings, voltage levels and connections.
