Forum >SEN0485 Resolution?
General Gravity
SEN0485 Resolution?
userHead ching.lui 2024-12-11 02:14:46 611 Views2 Replies
What's the sensing resolution for the Gravity: Capacitive Non-contact Liquid Level Sensor(3mm TR, IP67), SEN0485?
Thanks!
2024-12-11 10:22:19
This sensor has a sensing distance of 3mm and outputs a high and low level with no resolution parameter.
userHeadPic yiqing.guan
2024-12-11 10:12:08
This sensor doesn't output actual data, it just outputs a high level signal when it detects a liquid, so it doesn't have a resolution parameter.
userHeadPic Yeez_B
