Forum >Gravity Lightning Sensor SEN0290 Not Working Correctly
GravityGeneral
userHead Steve Pattinson 2024-12-13 11:35:30 1858 Views2 Replies
I have interfaced a gravity lightning SEN0290 sensor to an ESPC6-C6-Zero using the Arduino IDE and the example in the DFRobot web site. However, I can get no response from the lightning sensor (ie no response from IRQ pin) when attempting to trigger the device using a pizzo gas lighter and also a hand help VHF transceiver held close to the sensor.
I have ascertained that I'm talking to the the SEN0290 correctly by writing and then reading back a noise floor setting, and the program appears to be running correctly.
Ie
    noiseFloorG1 =  lightning0.getNoiseFloorLvl();
    Serial.print("Noise floor before is ");Serial.println(noiseFloorG1);
    noiseFloor = 5;
    lightning0.setNoiseFloorLvl(noiseFloor);
    Serial.print("Noise floor SET is ");Serial.println(noiseFloor);
    noiseFloorG2 =  lightning0.getNoiseFloorLvl();
    Serial.print("Noise floor after is ");Serial.println(noiseFloorG2);
this works as expected so I think the I2C is ok
Thinking that perhaps those sources above can't trigger the device, I tried commentating the lines intended for tuning and attached a CRO to the GND & IRQ pins as suggested.
Ie
   lightning0.setLcoFdiv(0);
   lightning0.setIRQOutputSource(3);
This just shows zero volts on the IRQ pin.
Strangely, if I set
   lightning0.setIRQOutputSource(1);
I get a 35.86 kHz square wave on the IRQ pin, and if I try
   lightning0.setIRQOutputSource(2);
I get a 1.3 MHz square wave.
I conclude from this that the IRQ output is active, but only when I set if for TRCO or SRCO (whatever they are) and not for LCO
If anyone has an idea of what might be wrong, or what I should look at next, I'd appreciate hearing.
Steve
2024-12-20 13:32:22
Hi lia,ifat,
It looks like I had indeed damaged the sensor, since it's replacement appears to work.
Cheers
Steve
userHeadPic Steve Pattinson
2024-12-16 21:23:26
Adjust sensitivity-related parameters like Noise Floor, Watchdog Threshold, and Spike Rejection.
userHeadPic lia.ifat
