Forum >Analog Electrochemical Carbon Dioxide Sensor [SEN0159] Not Giving Normal Data Feedback on Arduino
userHead Tonny12138 2024-12-23 09:42:23 2414 Views1 Replies
I am using this sensor on an Arduino, but the sensor is not giving me the normal data feedback.
2024-12-23 09:42:59
This sensor probe operates at 6V, we have integrated a boost circuit on the board, but this will draw a lot of current when using the sensor.
So if you are using a USB port to power the Arduino, this may often not be enough.
We recommend that you use a VIN or Barrel jack (DC2.1) to power the Arduino with 7~12V.
userHeadPic Tonny12138
