Forum >How Do I Test I2C Sensor Compatibility with Fermion: BLE Sensor Beacon?
userHead Tonny12138 2024-12-24 10:22:46 2483 Views1 Replies
2024-12-31 16:17:40
Unfortunately, given the small RAM of the BLE Sensor Beacon's on-board MCU, the I2C sensor does not support the "Run in RAM" test and can only be "Burned".
We recommend you to double check the I2C communication configuration before "Burn", as this step is irreversible.
We have designed our own .cfg configuration file for some Fermion sensors. You can download it from our Github repo.
If you need to integrate an I2C sensor in large quantities, you can raise an issue in this Github repo and we will evaluate your needs in a timely manner.
BLE Sensor Beacon Github repo:
https://github.com/DFRobot/DFRobot_FermionBLE
userHeadPic Tonny12138
