Forum >How to Reset the Beacon for a Second 'Run in RAM' Test on Fermion: BLE Sensor Beacon?
2024-12-24 10:23:57
Tonny12138
Currently, only digital/analog sensors support the "Run in RAM" test. When you are done with the test, you need to completely cut off the Beacon's power (both VCC and coin cell) to reset the Beacon.
Note:
If you are using the Arduino IDE with the esp32 BLE sample code which we posted in our wiki .
We recommend that you roll back the SDK to a Stable version instead of the Development version. This is because as of 2024.3.15, the development version of the SDK has a string matching error when compiling BLE related code, which means the ESP32-C6/H2 does not support our sample code in wiki now.
