Forum >Why does the serial monitor output "No Device!" when using a multi-gas sensor?
userHead Tonny12138 2024-11-29 10:14:19 162 Views1 Replies
2024-12-31 10:16:54
If you are using our sample code, check that the onboard dial is the same as the I2C address filled in the code.
And SEL code needs to dial to 0 to communicate using I2C.
userHeadPic Tonny12138
