Forum >Troubleshooting SEN0440 Gas Sensor: 0 ppm Readings for Alcohol and CO
userHead Tonny12138 2024-12-31 10:25:25 1379 Views1 Replies
SEN0440 (MiCS-5524 MEMS Gas Sensor) is powered by UNO 5V. However, the detected results for alcohol and CO are both showing 0 ppm. What could be the issue?
2024-12-31 10:27:58
Firstly, let's check if there are any poor connections in the circuit. We suggest using the code and connection method provided in the tutorial. The sensor needs to be preheated for a while before use. If the output still shows 0, it's possible that there is no alcohol or CO present in the surrounding environment, or the concentration is very low. You can try placing a volatile alcohol swab and the sensor in the same bag to test it. After preheating, you can set the CALIBRATION TIME to 0 so that you don't have to wait for 3 minutes each time.
userHeadPic Tonny12138
