Forum >Impact of Disabling Temperature Collection on BMP388 Altitude Data
userHead Tonny12138 2024-12-28 10:32:11 1517 Views1 Replies
If temperature collection is disabled, the altitude (pressure) data may drift (increase or decrease at a certain rate) significantly beyond the normal range and cannot stabilize.
2024-12-31 10:33:04
Temperature is originally used to calibrate the pressure. When measuring pressure, temperature collection should not be disabled.
userHeadPic Tonny12138
