Forum >What should be paid attention to when installing the CO2 sensor?
userHead Tonny12138 2024-12-01 16:25:25 1038 Views1 Replies
2024-12-31 16:25:46
Proper installation of CO2 sensors is crucial for accurate monitoring of indoor CO2 levels. Here are a few points to consider when installing the sensors:
Placement: CO2 sensors should be installed in areas where CO2 levels need to be monitored, such as enclosed rooms with poor air circulation. However, they should be placed away from areas that are easily disturbed or contaminated, such as near doors, windows, and ventilation ducts.
Avoid direct sunlight: Sensors should not be installed in direct sunlight to avoid temperature changes that may cause errors in measurements.
Avoid contamination: Sensors should be installed in clean, dust-free, oil-free, and chemical-free areas.
Avoid heat sources: Sensors should be placed away from heat sources to prevent high temperatures that may affect measurement accuracy.
userHeadPic Tonny12138
