After the sample code is uploaded to the 32x32 RGB LED Matrix screen, the color is dim or the display is abnormal (usually when one light is turn
2024-12-31 17:35:57
Check the library file used, because the version of the screen is different, the library file used is different, the wiki provides two library files, please test whether it can work separately (delete the other library file when using one library file); if it still displays an exception , please replace the stable external power supply.
