Forum >URM14 - Industrial Ultrasonic Distance Sensor with 1mm Accuracy ModBus Comms
Troubleshooting
userHead pais.bruno@gmail.com 2025-01-03 14:05:00 1115 Views2 Replies
Hi there,
I have tried to connect the URM14 - Industrial Ultrasonic Distance Sensor with 1mm Accuracy to different ModBus devices:
- WaveShare 4-Ch RS485 to RJ45 Ethernet Serial Server, 4 Channels RS485 Independent Operation- WaveShare Industrial Isolated USB To RS485/422 Converter- Sequent Microsystems Home Automation V4 8-Layer Stackable HAT for Raspberry Pi
Cannot get it to work with any.
Wire connections as follow:
Brown - 12VDC+
Black - 12VDC-
White - ModBus A
Blue - ModBus B
(I also tried to switch the A with B to no avail)
Slave address - Tried the 12 as per default on your wiki (https://wiki.dfrobot.com/URM14_RS485_Precision_Ultrasonic_Sensor_200KHz_SKU_SEN0358) and all the other ones between 0 and 13 in case there was something wrong there.
Baud Rate - Tried 19200 as per your wiki and also 9600.
Databits - 8 as per your wiki
Parity - None as per your wiki
Stopbits - 1 as per your wiki
Nothing seems to work and it timeouts everytime.
Any help?
Cheers,
b.
2025-02-26 01:13:45
did you manage to get it to work? I should also connect it to a PC
userHeadPic Marco.Porcari
2025-01-14 16:50:00
Here might be able to help you   https://www.zouser.com/
userHeadPic 黑黑.森尔
