Forum >IR Thermometer Sensor has data reversed on SCI DAQ
TroubleshootingGravity
userHead gloyer@gmail.com 2025-01-04 08:00:44 273 Views1 Replies
I have an IR Thermometer Sensor plugged into a Gravity SCI DAQ and the readings are showing up on the screen, but the Ambient and Object readings are reversed.  Putting my finger over the opening of the IR sensor increases the temperature that shows up on the Gravity SCI DAQ screen labeled as Temp-Amb. How can I correct the labeling for the data?
2025-01-07 11:23:51
The labels for the Object and Ambient temperatures are incorrectly swapped. We will correct this in the next firmware update!
userHeadPic Xiao
