Forum >Temperature Discrepancy Between SEN0335 and DPS310
TroubleshootingArduino
userHead Benoît.Urruty 2025-01-06 16:04:40 289 Views1 Replies
I have observed a noticeable temperature difference between the SEN0335 and DPS310 sensors, with the SEN0335 consistently reading about 3°C higher. I suspect this discrepancy might be caused by the heat generated by the air quality sensor in the SEN0335.
Have you encountered a similar issue before?
I’ve attached some data for your reference.
Best regards,
icon data_nuit.zip 3.15MB Download(0)
2025-01-14 16:48:00
Here might be able to help you   https://www.zouser.com/
userHeadPic 黑黑.森尔
