Forum >Problem with cascading visual rotary encoders
userHead Dkrigou.Har 2025-01-07 22:20:20 392 Views1 Replies
Hello !
i'm experiencing problems when trying to use 2 rotary encoders in i2c cascade to pilot 2 servo motors.
it works perfectly with one encoder and one servo, one encoder and 2 servos, but not with 2 encoders and 2 servos.
the 2 encoders have strange behaviour and no servo moves.
i'musing a PCA9685 i2c servo driver
attached is my code,
could you help me?
thanks !
best regards
//#include <Wire.h>                         // Wire Library for I2C Communications
#include <Adafruit_PWMServoDriver.h>      // Adafruit PWM Library for servos
#include <DFRobot_VisualRotaryEncoder.h>  // Library for DFrobot Encoder Potentiometer
// Variables and constants declaration *********************************************
// Servos Valves
#define MIN_PULSE_WIDTH  771  //650
#define MAX_PULSE_WIDTH  2193  //2350
#define FREQUENCY        50
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
// Define Valves Encoder Inputs
DFRobot_VisualRotaryEncoder_I2C PotServo(/*iicAddr = */0x54, /*iicBus = */&Wire);
//DFRobot_VisualRotaryEncoder_I2C PotServo2(/*iicAddr = */0x55, /*iicBus = */&Wire);
// Define Servo Outputs on PCA9685 board
const int ServoPin = 0;
const int Servo2Pin = 1;
// Servo valves *************************************************************************
void moveServo(DFRobot_VisualRotaryEncoder_I2C Encoder, int S_Pin)
 // with  Encoders
   if(Encoder.detectButtonDown()){
   // Reset encoders
     Encoder.setEncoderValue(0);
   int pulse_wide, pulse_width;
   uint16_t encoderValue = Encoder.getEncoderValue();
   Serial.print("The encoder currently counts: ");
   Serial.println(encoderValue);
  pulse_wide = map(encoderValue, 0, 1023, MIN_PULSE_WIDTH, MAX_PULSE_WIDTH);
  pulse_width = int(float(pulse_wide) / 1000000 * FREQUENCY * 4096);
   pwm.setPWM(S_Pin, 0, pulse_width);
   Serial.print("PulseWide: ");
   Serial.println(pulse_wide);
    Serial.print("PulseWidth: ");
   Serial.println(pulse_width);
   delay(10);
// Main Code *************************************************************************
 // put your setup code here, to run once:
 Serial.begin(9600);           // start serial
 pwm.begin();                  // start PWM
 pwm.setPWMFreq(FREQUENCY);    // set PWM Frequency
// Servos Encoders communication check
//while( NO_ERR != PotServo.begin() && NO_ERR != PotServo2.begin()){
while( NO_ERR != PotServo.begin() ){
   Serial.println("Communication with Encoder failed, please check connection");
   delay(2000);
 Serial.println("Begin Encoders ok!");
 PotServo.setEncoderValue(0);
 //PotServo2.setEncoderValue(0);
 // Set the 4 encoder gain coefficient : Accuracy range: 1~51, the minimum is 1 (light up one LED about every 2.5 turns), the maximum is 51 (light up one LED every one detent rotation
 PotServo.setGainCoefficient(51);
 //PotServo2.setGainCoefficient(51);
 // put your main code here, to run repeatedly:
moveServo(PotServo, ServoPin);
moveServo(PotServo2, Servo2Pin);
2025-01-08 16:53:58
Hello
i FOUND THE PROBLEM !
i did'nt understand that there is a physical switch on the back of the encoder (SEN0502) to set the i2c address !!
both encoder were on the same address
now i changed one encoder to 0x55 and it works !
userHeadPic Dkrigou.Har
