Forum >not getting usb serial on macbook
userHead Justin Eltoft 2025-01-08 10:21:48 147 Views1 Replies
When I connect usb to the dfplayer pro, it says “slave mode” over the attached speakers.  I don't have any usb serial devices listed through the command:
`ls /dev/{tty,cu}.*`
I am able to see the device as a flash drive in the finder though and copy audio files to it.
Is there some need to move to “AT command” mode to get a serial connection?  If so, how do I do that?  I am only powering the dfplayer pro through the usb cable at the moment.
The play button does work btw to play the audio files also.
The main reason I want this is to turn off the default factory audio per the FAQ
2025-01-10 00:39:37
meh, I just issued the command in code.
  DF1201S.setPrompt(false);
(would be nice if this forum supported markdown?)
userHeadPic Justin Eltoft
