Forum >Is it possible to connect SEN0390 with 4 pins?
General GravityArduino
userHead Hiroki.Tashiro 2025-01-13 19:09:50 161 Views1 Replies
The SEN0390 board has four holes, which looks like it can be fitted with a 4-pin terminal.
Can I use this 4-pin connector?
If so, what is the connector standard?
