Forum >Beetle CM-32U4, SKU DFR0816, question about how this mounts on the PCB?
userHead Eric.Redd 2025-01-15 07:19:58 954 Views1 Replies
Looking at the Beetle CM-32U4, seems like a good fit for a project I'm working on.
Clearly it takes a row of header pins on each side, which can plug into breadboard or a socket.
My question - the CM-32U4 has a second row of holes on each side of its PCB. What's the purpose of these?
Is it like the castellated holes on the sides of an Arduino Nano Every, which is meant to solder direct onto a PCB, without using any pins?
Thanks!
2025-02-17 06:35:06
Looking at the pictures - this board can't be mounted flat on a PCB, because it has components on the bottom of the PCB.
I can't see an alternative to mounting it with header pins. Any ideas, anyone?
And I'm puzzled about what the castellated holes are for.
userHeadPic Eric.Redd
