Forum >Problem SEN0539 with PICO
TroubleshootingGravity
userHead Pascal.FRANCOIS 2025-01-16 22:01:12 1012 Views1 Replies
problem with SEN0539 and Pico. I followed the video on your page but it does not work, I have a message " Write issue: Errno 5 EIO" I checked the wiring, the connection on the pico ports and the I2C switch. Everything is OK. Do you have an idea?
2025-01-17 17:36:21
The error [Errno 5 EIO (communication problem)] indicates mostly a wiring issue for I2C. I recommend to start after wiring with I2C scan.
userHeadPic Lupin
