Forum >O2 Gravity Factory Calibrated SEN0465 isn't giving accurate readings
userHead Elisheba.Tirzah 2025-01-17 15:11:54 1164 Views1 Replies
So I have been trying to read the oxygen values from the SEN0465 sensor for the past two days but am consistently getting innacurate values.
The output I'm getting is:
The device is connected successfully!
Ambient O2 concentration is: 20.90 %vol
Ambient  concentration is: 0.00 %vol
Ambient O2 concentration is: 19.20 %vol
When i keep it under a box it varies by 0.1 percentage (19.1). I don't know what I'm doing wrong. Also the following is my code
  * @file  readGasConcentration.ino
  * @brief Obtain gas concentration corresponding to the current environment, output as concentration value
  * @n Experimental mode: connect sensor communication pin to the main controller and burn
  * @n Communication mode select, DIP switch SEL: 0: I2C, 1: UART
  * @n Group serial number         Address in the group
  * @n A0 A1 DIP level 00    01    10    11
  * @n 1            0x60  0x61  0x62  0x63
  * @n 2            0x64  0x65  0x66  0x67
  * @n 3            0x68  0x69  0x6A  0x6B
  * @n 4            0x6C  0x6D  0x6E  0x6F
  * @n 5            0x70  0x71  0x72  0x73
  * @n 6 (Default address group) 0x74  0x75  0x76  0x77 (Default address)
  * @n 7            0x78  0x79  0x7A  0x7B
  * @n 8            0x7C  0x7D  0x7E  0x7F
  * @n i2c address select, default to 0x77, A1 and A0 are grouped into 4 I2C addresses.
  * @n             | A0 | A1 |
  * @n             | 0  | 0  |    0x74
  * @n             | 0  | 1  |    0x75
  * @n             | 1  | 0  |    0x76
  * @n             | 1  | 1  |    0x77   default i2c address
  * @n Experimental phenomenon: view the gas concentration corresponding to the current environment through serial port printing
  * @copyright   Copyright (c) 2010 DFRobot Co.Ltd (http://www.dfrobot.com)
  * @license     The MIT License (MIT)
  * @author      PengKaixing(kaixing.peng@dfrobot.com)
  * @version     V1.0
  * @date        2021-03-28
  * @url         https://github.com/DFRobot/DFRobot_MultiGasSensor
#include "DFRobot_MultiGasSensor.h"
//Turn on by default, using I2C communication at the time, switch to serial port communication after turning off
#define I2C_COMMUNICATION
#ifdef  I2C_COMMUNICATION
#define I2C_ADDRESS    0x74
  DFRobot_GAS_I2C gas(&Wire ,I2C_ADDRESS);
#else
 *    board   |             MCU                | Leonardo/Mega2560/M0 |    UNO    | ESP8266 | ESP32 |  microbit  |   m0  |
 *     VCC    |            3.3V/5V             |        VCC           |    VCC    |   VCC   |  VCC  |     X      |  vcc  |
 *     GND    |              GND               |        GND           |    GND    |   GND   |  GND  |     X      |  gnd  |
 *     RX     |              TX                |     Serial1 TX1      |     5     |   5/D6  |  D2   |     X      |  tx1  |
 *     TX     |              RX                |     Serial1 RX1      |     4     |   4/D7  |  D3   |     X      |  rx1  |
/* Baud rate cannot be changed  */
  #if defined(ARDUINO_AVR_UNO) || defined(ESP8266)
    SoftwareSerial mySerial(4, 5);
    DFRobot_GAS_SoftWareUart gas(&mySerial ,9600);
  #elif defined(ESP32)
    DFRobot_GAS_HardWareUart gas(&Serial1 ,9600 ,/*rx*/D2 ,/*tx*/D3);
  #else
    DFRobot_GAS_HardWareUart gas(&Serial1 ,9600);
  #endif
#endif
  //Serial port init for viewing printing output
  Serial.begin(115200);
  //Sensor init, used to init serial port or I2C, depending on the communication mode currently used
  while(!gas.begin())
    Serial.println("NO Deivces !");
    delay(1000);
  Serial.println("The device is connected successfully!");
  //Mode of obtaining data: the main controller needs to request the sensor for data
  gas.changeAcquireMode(gas.PASSIVITY);
  delay(1000);
   *Turn on temperature compensation: gas.ON : turn on
   *             gas.OFF:turn off
  gas.setTempCompensation(gas.ON);
   *Fill in the parameter readGasConcentration() with the type of gas to be obtained and print
   *The current gas concentration
   *Print with 1s delay each time
  Serial.print("Ambient ");
  Serial.print(gas.queryGasType());
  Serial.print(" concentration is: ");
  Serial.print(gas.readGasConcentrationPPM());
  Serial.println(" %vol");
  Serial.println();
  delay(1000);
It is the example code from DFRobot_MultiGasSensor library
2025-01-23 01:38:24 Check if the sensor's DIP switch is set for I2C mode since your code is configured for I2C (#define I2C_COMMUNICATION).Verify the I2C address with I2C scanner code. See if it  is 0x74. Temporarily turn off temperature compensation by replacing gas.setTempCompensation(gas.ON); with gas.setTempCompensation(gas.OFF); and observe if the readings stabilize. If nothing helps, maybe it's bad hardware. If you think about making a blood oxygen sensor, you can see here: https://www.pcbway.com/blog/3/Blood_Oxygen_Sensor_OEM_example_fdc19b88.html userHeadPic lia.ifat
