Forum >L298N Motor Controller Board - does it work with PLC? (SKU: DRI0002)
Hey!
I have a L298N motor controller board. I'm trying to control it using a Siemens PLC with digital outputs. What i'm wondering really is if you can controll the pwn output with a digital signal to run the motor on permanent full speed. (I have controlled the motor before without the board on the same PLC, but my supervisor want me to try and make it work.)
Thank you!
Thank you!
2018-01-12 23:10:00 Do any of you know if the pins on the board are sensitive with the voltage they receive? Do i have to step down the voltage to a much lower voltage from the ordinary 24 volts from the PLC?
alehol99
2018-01-12 22:24:45 I didn't use PLC to control the driver before, but since two digital pins could control the motor driver as the wiki shows.
robert.chen
