Forum >SEN0214 Junk Data
GravityTroubleshooting
SEN0214 Junk Data
userHead Russell.Manning 2025-01-28 10:50:20 324 Views0 Replies
I haven't put a lot of time into it with other projects I've been working on but efforts in getting any useful data out of this SEN0214 has failed.  It ether doesn't really change with power draw or none, or it floats around super low values.  The GPIO's used are correct along with the wiring for measuring.
Snippet from Home Assistant for this sensor:
sensor:
  - platform: adc
    pin: GPIO33  # Use an ADC pin available on the ESP32
    name: "Current Sensor Raw Voltage"
    unit_of_measurement: "V"
    accuracy_decimals: 3
    attenuation: 11db  # Allow 3.3V input
    update_interval: 1s
  - platform: template
    name: "Measured Current (DC)"
    unit_of_measurement: "A"
    accuracy_decimals: 2
    update_interval: 1s
    lambda: |-
      // Read ADC voltage
      float v_adc = id(current_sensor_adc).state;
      // Reference Voltage (5V supply for SEN0214)
      const float Vref = 5.0;  // Sensor power supply
      // Midpoint Voltage (0A)
      const float midpoint = Vref / 2.0;  // 2.5V
      // Sensitivity
      const float sensitivity = 0.1;  // 100mV per amp
      // Calculate current
      float current = (v_adc - midpoint) / sensitivity;
      return abs(current) > 0.05 ? current : 0.0;  // Filter small noise values
Any pointers?
