Forum >Gravity: PM2.5 Air Quality Sensor data meaning issue
userHead Giovanni.Briguglio 2025-02-04 00:20:20 1565 Views2 Replies
I bought a Gravity: PM2.5 Air Quality Sensor and I connected it to a Raspberry Pi 4. By means of I2C interface I recognized that there are several addresses from which taking data. I checked the datasheet but I did not find any protocols from which understanding data. I tried one of those addresses but data changes rapidly and greatly… Can you help me to understand how to get the correct values?
2025-02-25 14:39:37
Have you tried downloading the driver and examples from github?
https://github.com/DFRobot/DFRobot_AirQualitySensor/tree/master
The examples there seem very straightforward, so I would try one.
The initialization code for both examples is the same:
I2C_1       = 0x01               # I2C_1 Use i2c1 interface (or i2c0 with configuring Raspberry Pi file) to drive sensor
I2C_ADDRESS = 0x19               # I2C Device address, which can be changed by changing A1 and A0, the default address is 0x54
airqualitysensor = DFRobot_AirQualitySensor(I2C_1 ,I2C_ADDRESS)
That should create an object you can query to get measurements.
For example, you might try (in Python)
pm1_standard_reading = airqualitysensor.gain_particle_concentration_ugm3(PARTICLE_PM1_0_STANDARD)
print(pm1_standard_reading)
Which should give you the sensors reading of that value.
Hope that's helpful.
userHeadPic sean.catheroy
sean.catheroy wrote:
PS - You shouldn't need to worry about finding the device on I2C - seems like DFRobot has taken care of that for you if you use the driver they provide.
2025-02-25 14:41:37
