Forum >SEN0465 O2 sensor with Microbit
TroubleshootingGravity
userHead Marc-André.Mercier 2025-02-06 03:36:59 1012 Views0 Replies
Hello.
I'm trying to use the SEN0465 O2 sensor with the Micro:bit but it doesn't work.  I looked for a extension to use with the microbit and i didn't find one.  Also, I tryed looking on the web with no result.  I was able to make it wor with Arduino but not with the Micro:bit.  Will it work with the microbit and what would be the code that I sould use.  Preferably with block programming.  Thank's
