Forum >Plantower PM2.5 Sensor
userHead Stanley.Parker 2025-02-13 01:34:17 1293 Views2 Replies
hi,
I am trying to connect a plantower Pm2.5 sensor (PMS5003) to my Firebeetle ESP32 v
I cannot get a reading from it
2025-02-13 10:15:37
* MindPlus
* firebeetleesp32
#include "DFRobot_AirQualitySensor.h"
DFRobot_AirQualitySensor_I2C particle(&Wire, 0x19);
Serial.begin(9600);
while(!particle.begin())
 delay(500);
Serial.println((particle.gainParticleConcentration_ugm3(PARTICLE_PM2_5_STANDARD)));
You can try like this. I hope this can help you.
userHeadPic sun.haihui
2025-02-13 01:42:55
Sorry some of the text got cut off in the main post, the firebeetle is a DFR0478,
I am looking for code that I can use to get readings from the sensor and test it is working,
Thank you
userHeadPic Stanley.Parker
