can i use mutiple features like get GPS SEND SMS and send http request at the time on the sim 808
it wont allow me to send messages after the request
#include <DFRobot_SIM808.h>
DFRobot_SIM808 sim808(&Serial);
float lat = 0.0;
float lon = 0.0;
char buffer[512];
char http_cmd[256];
#define PHONE_NUMBER "0884348727"
//mySerial.begin(9600);
Serial.begin(9600);
//******** Initialize sim808 module *************
while (!sim808.init()) {
delay(1000);
Serial.print("Sim808 init error\r\n");
//************* Turn on the GPS power************
// sim808_send_cmd()
if (sim808.attachGPS())
Serial.println("Open the GPS power success");
else
Serial.println("Open the GPS power failure");
//************** Get GPS data *******************
// Serial.println("attempting to get data ");
if (sim808.getGPS()) {
Serial.print(sim808.GPSdata.year);
Serial.print("/");
Serial.print(sim808.GPSdata.month);
Serial.print("/");
Serial.print(sim808.GPSdata.day);
Serial.print(" ");
Serial.print(sim808.GPSdata.hour);
Serial.print(":");
Serial.print(sim808.GPSdata.minute);
Serial.print(":");
Serial.print(sim808.GPSdata.second);
Serial.print(":");
Serial.println(sim808.GPSdata.centisecond);
Serial.print("latitude :");
Serial.println(sim808.GPSdata.lat,6);
Serial.print("longitude :");
Serial.println(sim808.GPSdata.lon, 6);
Serial.print("speed_kph :");
Serial.println(sim808.GPSdata.speed_kph);
Serial.print("heading :");
Serial.println(sim808.GPSdata.heading);
Serial.println();
lon = sim808.GPSdata.lon, 6;
lat = -sim808.GPSdata.lat, 6;
//************* Turn off the GPS power ************
sim808.detachGPS();
delay(2000);
sendR();
delay(2000);
sendGoogleMapsLink("0884348727");
void sendR(){
while(!sim808.join(F("internet"))) {
Serial.println("Sim808 join network error");
delay(2000);
// char http_cmd ="hello";
// String data = "GET /dumi/send.php?device_id=5555&lat="+ String(lat, 6)+"&lon="+String(lat, 6)+" HTTP/1.1\r\nHost: www.bluecoregames.com\r\n\r\n";
// char http_cmd[] = http_cmd.c_str();
snprintf(http_cmd, sizeof(http_cmd),
"GET /dumi/send.php?device_id=5555&lat=%.6f&lon=%.6f HTTP/1.1\r\nHost: www.bluecoregames.com\r\n\r\n",
lat, lon);
// const char* http_cmd = http_cmd.c_str();
//************ Successful DHCP ****************
Serial.print("IP Address is ");
Serial.println(sim808.getIPAddress());
//*********** Establish a TCP connection ************
if(!sim808.connect(TCP,"www.bluecoregames.com", 80)) {
Serial.println("Connect error");
}else{
Serial.println("Connect bluecore success");
//*********** Send a GET request *****************
Serial.println("waiting to fetch...");
sim808.send(http_cmd, sizeof(http_cmd)-1);
while (true) {
int ret = sim808.recv(buffer, sizeof(buffer)-1);
if (ret <= 0){
Serial.println("fetch over...");
break;
buffer[ret] = '\0';
Serial.print("Recv: ");
Serial.print(ret);
Serial.print(" bytes: ");
Serial.println(buffer);
break;
//************* Close TCP or UDP connections **********
sim808.close();
//*** Disconnect wireless connection, Close Moving Scene *******
sim808.disconnect();
void sendGoogleMapsLink(const char *recipient) {
if (lat != 0.0 && lon != 0.0) {
String googleMapsLink = "https://www.google.com/maps?q=" + String(lat, 6) + "," + String(lon, 6);
if (sim808.sendSMS(recipient, googleMapsLink.c_str())) {
Serial.println("Sent SMS with Google Maps link: " + googleMapsLink);
} else {
Serial.println("Failed to send SMS.");
} else {
Serial.println("GPS data unavailable, cannot send link.");
Can you show me your error message?
it does not show any error i used Serial.println("Failed to send SMS.");
as a way to check if it send the sms
