Forum >SEN0205 Splashproofness for HIGH/LOW Readings
I am creating a sort of dishwasher with spray nozzles. I want to have a water level sensor in the appliance just in case the drain is blocked and fills with water past a certain point.
Is SEN0205 able to deal with water splashing on it for its signals for HIGH/LOW or will it give fault positives?
Thanks in advance
2025-02-18 11:49:41
sun.haihui
I don't think this sensor can meet your needs. Water splashing on it may affect the readings.
