Forum >Beetle ESP32 C6 Mini - WiFi not connecting after a low battery cycle
userHead Tink.Praston 2025-02-14 03:17:35 796 Views1 Replies
Hi there,
I'm using the Beetle ESP32 C6 mini board and have a project which has been working until now to connect to one of a number of WiFi networks using code with WiFiMulti.
My project runs off a LiPo battery connected across the BAT/GND pins and charged using the on-board lithium charging, which seems to work fine. I recently allowed the battery to run down fully overnight (in order to get a feel for battery life etc) and tracked battery voltage via some network calls. As expected, the battery voltage gradually decreased overnight and then dropped off, at which point I stopped “hearing” from the device.
The problem is that since then, the board has refused to connect to WiFi. This is tested on the two networks it was previously happily working on, and a new one. In all cases, it now hangs on waiting for a
while (wifiMulti.run() != WL_CONNECTED) { delay(1); }
line. I can include surrounding code if necessary but I believe this to be possibly a firmware / hardware issue since I haven't changed the code since it worked. The only lines concerning this are basically:
WiFiMulti wifiMulti;wifiMulti.addAP(WIFI_NETWORK_NAME_1, WIFI_NETWORK_PASSWORD_1);
Questions I've wondered but can't answer:
1. Does the board have any kind of cached network information that may have become corrupted when power unexpectedly fell off?
2025-02-14 03:27:00
Sorry, editor became a little weird as I was adding the sample code.
We have:
wifiMulti.addAP(WIFI_NETWORK_NAME_2, WIFI_NETWORK_PASSWORD_2);
userHeadPic Tink.Praston
