Forum >DF2301QG V1.0 stops working after a while ( few minutes ) needs reset to work again, why?
General Gravity
userHead wim.verlinden 2025-02-14 20:15:56 2473 Views6 Replies
The DF2301QG V1.0 Voice recognition module works well after a reset but stops working after a while not the same time, sometimes a few minutes is enough , it does not respond anymore to the wake word until I reset the module.
The module is connected to an ESP32 and is running below program:
What can be the reason/solution? Other people have this problem too?
* @file uart.ino
* @brief  Control the voice recognition module via UART
* @n  Get the recognized command ID and play the corresponding reply audio according to the ID;
* @n  Set the wake-up state duration, set mute mode, set volume, enter the wake-up state, and reset the module
* @copyright  Copyright (c) 2010 DFRobot Co.Ltd (http://www.dfrobot.com)
* @licence  The MIT License (MIT)
* @author  [qsjhyy](yihuan.huang@dfrobot.com)
* @version  V1.0
* @date  2022-12-30
* @url  https://github.com/DFRobot/DFRobot_DF2301Q
esp32 SERIAL1 RX=D3=>GROEN TX=D2=>BLAUW
#include "DFRobot_DF2301Q.h"
* @brief DFRobot_URM13_RTU constructor
* @param serial - serial ports for communication, supporting hard and soft serial ports
* @param rx - UART The pin for receiving data
* @param tx - UART The pin for transmitting data
#if (defined(ARDUINO_AVR_UNO) || defined(ESP8266))   // Use software serial
 SoftwareSerial softSerial(/*rx =*/4, /*tx =*/5);
 DFRobot_DF2301Q_UART DF2301Q(/*softSerial =*/&softSerial);
#elif defined(ESP32)   // Use the hardware serial with remappable pin: Serial1
 DFRobot_DF2301Q_UART DF2301Q(/*hardSerial =*/&Serial1, /*rx =*/21, /*tx =*/22);
#else   // Use hardware serial: Serial1
 DFRobot_DF2301Q_UART DF2301Q(/*hardSerial =*/&Serial1);
#endif
 Serial.begin(115200);
#if defined(ARDUINO_SAM_ZERO)   // The M0 board needs to be initialized at this time
 Serial1.begin(DF2301Q_UART_BAUDRATE);
#endif
 // Init the sensor
 while( !( DF2301Q.begin() ) ) {
   Serial.println("Communication with device failed, please check connection");
   delay(3000);
 Serial.println("Begin ok!");
  * @brief Reset the module
 // DF2301Q.resetModule();
  * @brief Set commands of the module
  * @param setType - Set type
  * @n       DF2301Q_UART_MSG_CMD_SET_VOLUME : Set volume, the set value range 1-7
  * @n       DF2301Q_UART_MSG_CMD_SET_ENTERWAKEUP : Enter wake-up state; set value 0
  * @n       DF2301Q_UART_MSG_CMD_SET_MUTE : Mute mode; set value 1: mute, 0: unmute
  * @n       DF2301Q_UART_MSG_CMD_SET_WAKE_TIME : Wake-up duration; the set value range 0-255s
  * @param setValue - Set value, refer to the set type above for the range
//  DF2301Q.settingCMD(DF2301Q_UART_MSG_CMD_SET_MUTE, 0);
//  DF2301Q.settingCMD(DF2301Q_UART_MSG_CMD_SET_VOLUME, 5);
//  DF2301Q.settingCMD(DF2301Q_UART_MSG_CMD_SET_WAKE_TIME, 20);
 // DF2301Q.settingCMD(DF2301Q_UART_MSG_CMD_SET_ENTERWAKEUP, 0);
  * @brief Play the corresponding reply audio according to the command word ID
  * @param CMDID - Command word ID
 DF2301Q.playByCMDID(23);
  * @brief Get the ID corresponding to the command word
  * @return Return the obtained command word ID, returning 0 means no valid ID is obtained
 uint8_t CMDID = 0;
 CMDID = DF2301Q.getCMDID();
 if(0 != CMDID) {
   Serial.print("CMDID = ");
   Serial.println(CMDID);
 delay(2000);
2025-05-04 20:30:58
Add this in your setup() (you've commented it out):
DF2301Q.settingCMD(DF2301Q_UART_MSG_CMD_SET_WAKE_TIME, 255); // Max wake time
userHeadPic ahsrab.rifat
2025-05-04 09:32:20
I ran into the same thing, only works with one or two commands, but then it stops working after it turns off the listening mode. Any update from anyone on how to fix this?
userHeadPic Carlos.Hernandez8340
Carlos.Hernandez8340 wrote:
Update: UART doesn't make it freeze. I recommend you use it with UART communication to prevent the freeze. Left it on for hours, ran commands over and over again, still worked.
2025-05-04 11:22:44
2025-04-03 13:34:14
Yes, it worked for me in I2C mode. However, I found what seems to be a fatal firmware bug, as follows.
At the end of the wake period the DFR goes to sleep, as expected. However in doing so it sometimes pulls the SDA and SCL lines low and doesn't release them.
This not only crashes the DFR and any other I2C devices on the I2C bus but it is unrecoverable without a DFR power-reset.
I tried various software techniques to keep the DFR permanently awake; but alas, they all failed.  Any extensions of the wake mode seems timeout seems to depend only on the receipt of a valid voice command whist the module is awake.
userHeadPic Michael.Morton
2025-03-20 20:45:02
In my case I was using a clone Nano and it was freezing randomly and I think buffer was getting full up. Using Serial.flush(); seemed to help but still froze. I bought Nano ESP32 and so far seems ok. Only thing I have to sort is long cable for I2C connection. Needs to be short or twisted pairs to stop lag or not seeing SEN0539-EN. If your cable from dev board to SEN0539 is long may be better using IC2 than UART its faster ;-)
userHeadPic TrickyZXR
TrickyZXR wrote:
Should have said original Arduino Nano ESP32 not a clone ;-)
2025-03-20 20:56:20
