Forum >Possible to connect more tan one 4-20mA module via I2C (DFR0972)?
How to select
userHead Manney.Kerkkamp 2025-02-18 19:54:59 100 Views1 Replies
For a project I need 3 analog outputs 4-20mA but on the documentation af the DFR0972 I only see one I2C adress.
Is it possible to control more than one unit via the same I2C bus?
2025-03-18 09:38:36
If you want to use three DFR0972 at the same time, we recommend purchasing one DFR0759 (I2C HUB) to implement your idea.        DFR0759:重力:I2C HUB Arduino - DFRobot --- Gravity: I2C HUB Arduino - DFRobot
userHeadPic Zane
