Forum >audio commands error
userHead Gavin.Jackson 2025-02-21 00:42:40 1379 Views0 Replies
ive been putting together a project called tillu by Mukesh Sankhla, however im running into a problem with voice commands causing the below error. any help appreciated
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.iec958
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib pcm_oss.c:377:(_snd_pcm_oss_open) Unknown field port
ALSA lib pcm_a52.c:823:(_snd_pcm_a52_open) a52 is only for playback
ALSA lib conf.c:5014:(snd_config_expand) Unknown parameters {AES0 0x6 AES1 0x82 AES2 0x0 AES3 0x2 CARD 0}
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM iec958:{AES0 0x6 AES1 0x82 AES2 0x0 AES3 0x2 CARD 0}
ALSA lib pcm_usb_stream.c:486:(_snd_pcm_usb_stream_open) Invalid type for card
Listening for commands...
Exception in thread Thread-7:
Traceback (most recent call last):
File "/usr/lib/python3.7/threading.py", line 917, in _bootstrap_inner
self.run()
File "/usr/lib/python3.7/threading.py", line 865, in run
self._target(*self._args, **self._kwargs)
File "/root/Tillu/main.py", line 71, in voice_listener
command = listen_for_command()
File "/root/Tillu/speech_text.py", line 41, in listen_for_command
recognized_text = recognizer.recognize_google(audio).lower()
File "/usr/local/lib/python3.7/dist-packages/speech_recognition/init.py", line 881, in recognize_google
convert_width=2 # audio samples must be 16-bit
File "/usr/local/lib/python3.7/dist-packages/speech_recognition/init.py", line 495, in get_flac_data
flac_converter = get_flac_converter()
File "/usr/local/lib/python3.7/dist-packages/speech_recognition/init.py", line 1744, in get_flac_converter
raise OSError("FLAC conversion utility not available - consider installing the FLAC command line application by running apt-get install flac or your operating system's equivalent")
OSError: FLAC conversion utility not available - consider installing the FLAC command line application by running apt-get install flac or your operating system's equivalent
