Forum >MEMS CO Sensor Datasheet is incomplete
TroubleshootingArduino
userHead sean.catheroy 2025-02-24 05:04:39 89 Views0 Replies
The datasheet for this part states that package is sensitive to CO between 5 -5000ppm, but provides no equation on how to translate to that scale.
I have seen comments on this forum stating this part cannot give an accurate PPM count. That was understood when buying the part as this is clearly stated.
I am not asking for a precise number - a relative reading between 5 and 5000 is fine.
I am asking for guidance on the intended way to translate a voltage or ADC Value into the relative scale of 5 to 5000ppm, as the datasheet is not at all clear on how to do this.
For example - one presumes the following:
Vin = ADC_value / ADC Resolution * Vref
Questions: 1) Is this the intended translation?2) If this is the intended translation, how does Vin relate to a value between 5 and 5000ppm?
3) If there is some other intended translation, please provide it.
Thank you.
