Forum >Beetle CM-32U4 Wiki Incorrect Pin Numbering on diagram
After a lot of grief thinking my newly received boards were faulty, I've discovered the pin numbering on the main wiki page for the Beetle CM-32U4 is incorrect :
PIN labelled PWM/Digital Port 10 is actually Digital Port 11 (also incorrect on schematic)
PIN labelled Digital Port 17 is actually Digital port 14 (it is correct on the schematic and is MISO/SPI as labelled)
