Forum >DFR1075 - Firebeetle 2 - ESP32-c6 analog read
userHead iisfaq 2025-03-02 07:45:04 790 Views2 Replies
I have a simple app that performs an Analog read from A1 (ADC1_2) and A2 (ADC1_3)
I have a LDR connected to 10K resister and I am reading this value.
The ADC 1 channel 2 gives me a light value of 192 and a dark value of 1456.
The ADC 1 channel 3 gives me a light value of 176 and a dark value of 336
Why is this?
I have tried disabling pull up and pull down on the channels. Made no difference.
The pins appear to be quite generic and not really connected to anything else.
I am wondering why the difference in values. And is there any way to make them the same value?
I am using ESP-IDF because arduino IDE seems to have issues with serial ports on these devices now. Also I could not upload the code as a file as it says 10MB.
 * SPDX-FileCopyrightText: 2022-2023 Espressif Systems (Shanghai) CO LTD
 * SPDX-License-Identifier: Apache-2.0
 #include <stdio.h>
 #include <stdlib.h>
 #include <string.h>
 #include "freertos/FreeRTOS.h"
 #include "freertos/task.h"
 #include "soc/soc_caps.h"
 #include "esp_log.h"
 #include "esp_adc/adc_oneshot.h"
 #include "esp_adc/adc_cali.h"
 #include "esp_adc/adc_cali_scheme.h"
 #include "driver/gpio.h"
 const static char *TAG = "EXAMPLE";
         ADC General Macros
 //ADC1 Channels
 #define EXAMPLE_ADC1_CHAN0          ADC_CHANNEL_2
 #define EXAMPLE_ADC1_CHAN1          ADC_CHANNEL_3
 // GPIO pins corresponding to ADC channels
 #define GPIO_ADC1_CHAN0             2  // GPIO 2 for ADC Channel 2
 #define GPIO_ADC1_CHAN1             3  // GPIO 3 for ADC Channel 3
 #define EXAMPLE_ADC_ATTEN           ADC_ATTEN_DB_12
 static int adc_raw[2];  // Store one reading per channel
 static bool do_calibration = true;
 static adc_cali_handle_t adc1_cali_handle = NULL;
 static bool init_adc_calibration(void) {
     esp_err_t ret = ESP_FAIL;
     bool calibration_enabled = false;
 #if ADC_CALI_SCHEME_CURVE_FITTING_SUPPORTED
     if (!calibration_enabled) {
         ESP_LOGI(TAG, "Calibration scheme: Curve Fitting");
         adc_cali_curve_fitting_config_t cali_config = {
             .unit_id = ADC_UNIT_1,
             .atten = EXAMPLE_ADC_ATTEN,
             .bitwidth = ADC_BITWIDTH_12,
         ret = adc_cali_create_scheme_curve_fitting(&cali_config, &adc1_cali_handle);
         if (ret == ESP_OK) {
             calibration_enabled = true;
 #endif
 #if ADC_CALI_SCHEME_LINE_FITTING_SUPPORTED
         ESP_LOGI(TAG, "Calibration scheme: Line Fitting");
         adc_cali_line_fitting_config_t cali_config = {
         ret = adc_cali_create_scheme_line_fitting(&cali_config, &adc1_cali_handle);
 #endif
     return calibration_enabled;
 static void deinit_adc_calibration(void) {
     if (adc1_cali_handle) {
         adc_cali_delete_scheme_curve_fitting(adc1_cali_handle);
 #elif ADC_CALI_SCHEME_LINE_FITTING_SUPPORTED
         adc_cali_delete_scheme_line_fitting(adc1_cali_handle);
 #endif
 void app_main(void)
     // Disable pull-up/pull-down for ADC pins using direct register access
     // This is a simpler approach than using gpio_config
     gpio_pullup_dis(GPIO_ADC1_CHAN0);    // Disable pull-up on GPIO 2
     gpio_pulldown_dis(GPIO_ADC1_CHAN0);  // Disable pull-down on GPIO 2
     gpio_pullup_dis(GPIO_ADC1_CHAN1);    // Disable pull-up on GPIO 3
     gpio_pulldown_dis(GPIO_ADC1_CHAN1);  // Disable pull-down on GPIO 3
     ESP_LOGI(TAG, "GPIO pins %d and %d configured with no pull-up/down resistors",
              GPIO_ADC1_CHAN0, GPIO_ADC1_CHAN1);
     //-------------ADC Calibration Init---------------//
     do_calibration = init_adc_calibration();
     if (!do_calibration) {
         ESP_LOGE(TAG, "Calibration failed to initialize. Using raw ADC readings.");
     //-------------ADC1 Init---------------//
     adc_oneshot_unit_handle_t adc1_handle;
     adc_oneshot_unit_init_cfg_t init_config1 = {
     ESP_ERROR_CHECK(adc_oneshot_new_unit(&init_config1, &adc1_handle));
     //-------------ADC1 Config---------------//
     adc_oneshot_chan_cfg_t config = {
         .bitwidth = ADC_BITWIDTH_DEFAULT,
     ESP_ERROR_CHECK(adc_oneshot_config_channel(adc1_handle, EXAMPLE_ADC1_CHAN0, &config));
     ESP_ERROR_CHECK(adc_oneshot_config_channel(adc1_handle, EXAMPLE_ADC1_CHAN1, &config));
     // Print confirmation of setup
     ESP_LOGI(TAG, "ADC configured with attenuation: %d", EXAMPLE_ADC_ATTEN);
     // Main loop for ADC readings
     while (1) {
         // Read from ADC Channel 2 (GPIO 2)
         ESP_ERROR_CHECK(adc_oneshot_read(adc1_handle, EXAMPLE_ADC1_CHAN0, &adc_raw[0]));
         ESP_LOGI(TAG, "ADC%d Channel[%d] (GPIO %d) Raw Data: %d",
                  ADC_UNIT_1 + 1, EXAMPLE_ADC1_CHAN0, GPIO_ADC1_CHAN0, adc_raw[0]);
         // Apply calibration if available
         if (do_calibration) {
             int voltage0 = 0;
             ESP_ERROR_CHECK(adc_cali_raw_to_voltage(adc1_cali_handle, adc_raw[0], &voltage0));
             ESP_LOGI(TAG, "ADC%d Channel[%d] (GPIO %d) Calibrated Data: %d mV",
                      ADC_UNIT_1 + 1, EXAMPLE_ADC1_CHAN0, GPIO_ADC1_CHAN0, voltage0);
         vTaskDelay(pdMS_TO_TICKS(250));
         // Read from ADC Channel 3 (GPIO 3)
         ESP_ERROR_CHECK(adc_oneshot_read(adc1_handle, EXAMPLE_ADC1_CHAN1, &adc_raw[1]));
                  ADC_UNIT_1 + 1, EXAMPLE_ADC1_CHAN1, GPIO_ADC1_CHAN1, adc_raw[1]);
             int voltage1 = 0;
             ESP_ERROR_CHECK(adc_cali_raw_to_voltage(adc1_cali_handle, adc_raw[1], &voltage1));
                      ADC_UNIT_1 + 1, EXAMPLE_ADC1_CHAN1, GPIO_ADC1_CHAN1, voltage1);
         vTaskDelay(pdMS_TO_TICKS(1000));
     // Note: This teardown code will never be reached due to the infinite loop
     ESP_ERROR_CHECK(adc_oneshot_del_unit(adc1_handle));
         deinit_adc_calibration();
2025-03-04 13:27:38
Why is this?
userHeadPic SDdgf456.Sg567
iisfaq wrote:
Are you asking me why I am doing this?
The ESP32-C6 has multiple Analog to Digital pins.
If I connect my LDR circuit with a 10K LDR and a 10K resister, I expect each pin to return the same values +/- a small variation.
This is not the case - if I block most of the light from getting to the LDR the value I read is
Using Pin 2 - 2200
Using Pin 3 - 705
Using Pin 4 - 2750
Using Pin 5 - 1040
Why are they not all the same value?   Why is there such a variation?
2025-03-06 12:11:01
