Forum >Gravity_VL53L0X SEN0245
userHead Luiz.Navarro 2025-03-05 04:22:10 1667 Views1 Replies
I am using the SEN0245 with a Raspberry Pi 4B to position a camera approximately 1 meter from the target in an industrial application. The industrial camera is already attached to the Raspberry Pi, and other controls in the system are also managed by the Raspberry Pi.
The SEN0245 is connected to the Raspberry Pi's I2C pins through the DFR0565. I am attempting to use the smbus library to send commands and receive responses, but I could not find any documentation detailing the correct message sequence to follow.
Could you provide documentation on how to use this sensor with the smbus library? Alternatively, is there a DFRobot Python library available that I can import?
I would greatly appreciate any help with this!
2025-03-08 02:42:20
Problem solved! I started translating the provided C++ code for Arduino to Python with smbus2 library, but to shortcut this task, I asked DeepSeek to do this translation. Wonderful! Deepseek generated a very good code that I tested and worked well. Now I have the SEN0245 working in Raspberry Pi 4B with Python.
userHeadPic Luiz.Navarro
