Forum >Hi!If I understand correctly, this module with antenna is the transmitter. Can the same module be used as receiver? So this would mean that I need to buy 2x this module to be able ...
userHead Tonny12138 2021-04-29 17:15:54 24 Views1 Replies
Hi!
If I understand correctly, this module with antenna is the transmitter. Can the same module be used as receiver? So this would mean that I need to buy 2x this module to be able to work?
2021-05-24 11:01:43
Hi Menno,
yes, you would need to get 2X of this module to use them as receiver and transmitter.
userHeadPic Tonny12138
