Forum >Does it comes with a pin and if so whether it is soldered to the company?
userHead Tonny12138 2022-02-28 18:38:29 16 Views1 Replies
2023-10-28 04:22:32
how do I change the address using a0, a1, a2? It seems they are already connected to VCC through the resistors, so is the default value 1,1,1? How would I change a pin to 0, thank you.
userHeadPic Tonny12138
