Forum >HelloDo you have sample code for this module?
userHead Tonny12138 2022-10-07 13:53:53 266 Views1 Replies
Hello
2023-01-12 13:36:40
After testing this sensor for a couple months found that it is not very accurate when outdoors. The temperature sensor read off the charts when in sunlight and the humidity was very erratic. Once the sensor reads over 43C (Which didn't take much sunlight) it then reads a -180C value. After trending when in sunlight I noticed that the temperature curve followed the light intensity curve so not good for outdoors, so defeats the purpose of having UV when it can't work outside. Seems to work fine indoors. Needed to write some extra function for the barometric pressure as it always was reading 10hpa under than what the actual pressure was.
It was connected to a firebeetle ESP32-E as I was monitoring the data over MQTT every 5 seconds
userHeadPic Tonny12138
