Forum >Hi, I bought the sensor 6 months back and now the reading is stuck at 0.01ppm and not increasing even while interfering with alcohol. What should I do?
userHead Tonny12138 2024-08-16 01:37:24 27 Views1 Replies
2023-01-03 15:16:58
Hi, Sorry, there are no detailed parameters related to the calibration accuracy of this sensor at present. Since the sensor is an electrochemical sensor, the data may be offset when used. Please try to maintain a stable voltage and avoid the sensor from contacting interference gas (see wiki for interference gas).
userHeadPic Tonny12138
