Forum >I feel that every time I purchase a product from DF Robot I'm left with no support and sub-par implementations. Don't get me wrong, the hardware is great, but the firmware / librar...
userHead Tonny12138 2024-04-09 22:07:14 26 Views3 Replies
I feel that every time I purchase a product from DF Robot I'm left with no support and sub-par implementations. Don't get me wrong, the hardware is great, but the firmware / libraries that are (sometimes) included are not operable.
In this instance the firmware on the chip reports latitude and longitude incorrectly. I'm not sure how to proceed forward with fixing this, there's no documentation (that I can find) on the issue. But now I've got to dedicate a day or three to figure out this issue, hopefully fix it before trying to use this in my project.
This isn't the first time something from DFRobot has blocked my project progress, but hopefully it'll be the last time (I won't be buying more from DFRobot)
2024-07-18 22:14:03
Hi, I can't get a green light even when I have it right up against the window. It's always red. Do I have a defective product? Is there something else I should try? I checked the forum and didn't find anything - any help is appreciated.
userHeadPic Tonny12138
2024-05-28 10:53:29
can i get the datasheet for this module plz ?
it just keep the green led turned on
and no output coming out
2024-02-18 09:29:35
Sorry, the Raspberry library does not have either of these features at this time.
This is because the I2C/UART baud rates are fixed parameters set in the GNSS on-board MCU.
And there is no option to change the baud rate in Raspberry library.
