Forum >How long of a cable does it support (i.e. how far from the controller can it be?) If it was placed outside, it would be helpful if the controller could be placed in a more secure l...
If it was placed outside, it would be helpful if the controller could be placed in a more secure location.
2024-03-01 10:10:26
Tonny12138
Since Lark uses UART (TTL) as well as I2C communication. So we recommend that the cable length should not exceed 2 meters.
If you are placing it outdoors, we think you can use the sensor alone, powering the Lark with USB-C, and then the Lark will automatically record the relevant data.
Would you tell us about your usage scenario? Because we are thinking about developing an extension device for Lark. Your suggestion will play a vital role in our subsequent product development.
