Forum >for a 12v power supply, what is the smallest number of watts i need to run the full lite board?
userHead Tonny12138 2024-04-17 07:33:17 20 Views5 Replies
2024-05-02 08:09:46
Only 1 of the USB 3.0 ports is working. The rest of the ports 3.0 and 2.0 are not, even though they are enabled in the BIOS. M.2 E is also doing the same thing. Am I missing something simple or is there an issue with the board?
userHeadPic Tonny12138
Tonny12138 wrote:
You can seek technical support for LattePanda products through the LattePanda Forum or at the following e-mail address.
admin@lattepanda.com
2024-05-07 14:28:25
2024-04-25 10:16:07
Sorry, we do not have the stp file of the carrier board. We only have the STP file of the MU for your reference.
https://github.com/LattePan...
2024-04-17 18:40:54
Will there be a suitable case for the Lite Carrier? Ideally one where the carrier module and a cooler also fit?
2024-04-17 11:16:35
We don't have data on this one. When you use the Lite carrier board, we strongly recommend 12V@10A or higher power supply, as the MU power consumption may be greater than 10A.
If the current is not satisfied it may cause the MU to shut down abnormally.
