Forum >SCT-013-020 and Arduino R4 Wifi
Hello. I'm using an Arduino R4 Wifi with your SCT013-020 and ac module that came with it and ran the sample code. The AMPs displayed are a bit off. If I connect it up to an Arduino Uno, it works fine (the readings are close enough to the professional ammeter I have).
The sample code I am running is from: https://wiki.dfrobot.com/Gravity_Analog_AC_Current_Sensor__SKU_SEN0211_
I was wondering if I need to tweak the code a bit? And if so, do you have any suggestions. I'm getting lower Amperage readings. For example a reading of 7.0 Amps comes in around 5.8 to 5.9 amps. The arduino Uno get's closer - like 6.4 to 6.9.
Thanks for your help.
